Gas hob won't stop sparking
Discussion in 'Kitchen Fitters' Talk' started by Gazzoowen, Aug 1, 2009.
  1. Gazzoowen
    Gazzoowen New Member
    My stoves gas hob won't stop sparking even when all the knobs are in the off position. The problem seems to be with the back right ring because if I turn that one on and light it - the sparking stops - all other rings function ok. Any ideas?
  2. palatine
    palatine New Member
    If you take the fuse out t will stop sparking.
    Why did you choose a Stoves?
  3. stellaartois7
    stellaartois7 New Member
    Has your misses spilt a pan or just gave it a good clean? give it afew days to dry out or try a hair dryer at the back of the the ignition
  4. PAG
    PAG New Member
    Ive had this problen in the past and was due to
    over-tightening the clamps which hold the hob down.Hobs with the controls at the front are most most common for this.
