GAS METER FITTING
Discussion in 'Plumbers' Talk' started by GAS METER FITTING, Oct 19, 2010.
  1. GAS METER FITTING
    GAS METER FITTING New Member
    I GOT A GAS METER OF BK-G4 Natural Gas Diaphragm Meter AND THE GAS PIPE IS 1.1/4" AND GAS METER ADAPTOR IS ONE INCH. STRUGGLED A LOT TO FIT INTO THE GAS METER WHICH ONE SIZE WILL BE EXACTLY SUITABLE FOR GAS METER TO THE GAS PIPE. AND IF ANYONE KNOWS GAS FITTERS OR GAS CONNECTORS SHOP IN SHEFFIELD, SOUTHYORKSHIRE IS THERE TO GUIDE ME IT WILL BE HELPFUL TO CONNECT THE METER.
    REGARDS
    HARIHARAN GUNASEKARAN
    [Edited by: admin]
  2. Bill the Scot
    Bill the Scot New Member
    Should this not be installed by gas supplier or at least a qualified gas fitter as they have all necessary connections. Don't muck about with something you know little about.
    Remember gas can and does cause death. KABOOM!!!!!
  3. G Brown
    G Brown New Member
    You should NOT be doing this. The meter is the property of National Grid and they will take a very dim view of you fiddling with it. You could even find yourself in court.
  4. larnacaman
    larnacaman New Member
    I'm Afraid Those two replies of wisdom, along with the words they contained, ...will in all probability be ''Like Water Off A Ducks back!!!''
  5. superfurryanimal
    superfurryanimal New Member
    lol
    BOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOM
    [Edited by: admin]
  6. G Brown
    G Brown New Member
  7. chris roast
    chris roast Member
    tommorrows headlines, man blows himself up, trying to bypass meter lol
  8. superfurryanimal
    owe HARIHARAN GUNASEKARAN *
    watch this ....
    now put your hand in your pocket fella :'( geta gas safe engineer out :)
    [Edited by: admin]
  9. Captain Leaky
    Captain Leaky New Member
    Goodness Gracious Me! :O
  10. roythehandyman
    roythehandyman New Member
    Give the guy a break, Get a meter or so of hosepipe, stick end in a jug of boiling water, when the end is soft just ease it over the outlet, connect the other end to a cooker or gas fire. Make sure you do a "smoke test" sit cross legged in front of the meter, Place cigarette in mouth and strike match. If you manage to smoke the entire cigarette then the joint has passed the first test. Next do the same test whilst sitting in front of the appliance. If that passes the test then you are privatly qualified as a gas safe fitter. You should then contact british gas and invite them around to view your completed work. make sure they give you your gas safe registration number before they rush off!
  11. palavaman
    palavaman Well-Known Member
    I don't fink BG will give him a number:(
  12. chris roast
    chris roast Member
    maybe he could ring Gassafe and ask them to talk hime though the process of fitting a meter, if he manages to fit it without blowing himself up, he be qualified adn giving a number
  13. palavaman
    BG or Gas Safe won't be able to give him a number cos he'd be gone by then. To planner Zuss:p
  14. EXPERTGASMAN
    EXPERTGASMAN New Member
    Don't you guys recognise a wind up when it's around? lol
