Gas Pipe Bonding?
Discussion in 'Electricians' Talk' started by Mosaix, Nov 14, 2017.
  1. Mosaix
    Mosaix Member
    My daughter's just had her annual gas boiler maintenance.
    All passed ok but... she says (her words) 'he mentioned that the gas meter has a wire missing but he didn't need to include it in the report'
    I assume from that that he thinks the incoming gas pipe should be bonded?
    Is this a strict requirement? Should she get it done?
    Thanks in anticipation.
  2. dobbie
    dobbie Well-Known Member
    There should be a 10mm earth wire from the main earth terminal to the main gas pipe.
    Mosaix likes this.
  3. retiredsparks
    ....clamped onto solid pipe....before any branches..preferably within 600mm of the meter....labelled.
    Then tested.
    RS
    dobbie likes this.
  4. Risteard
    Risteard Well-Known Member
    To be anal about it it's a protective conductor and a bonding conductor, but it certainly isn't an earth wire.
    leesparkykent likes this.
  5. dobbie
    I will remember to ask for a drum of 10mm protective conductor, and also a drum of 10 mm bonding conductor when I am in the Wholesalers.
  6. Dr Bodgit
    Dr Bodgit Well-Known Member
    Its equipotential bonding ;)
  7. retiredsparks
    ....... and when you come to do the job...connect 'both' to The Main EARTH terminal !:p
    Altho i do agree with my learned colleague Ricky, who as usual (well mostly) is correct...technically.
    Rs
  8. dobbie
    Electrician---Can I have a drum of 10mm protective conductor please.
    Wholesaler---Sorry that does not seem to be on our stock list.
    Electrician---Can I have a drum of 10mm bonding conductor please.
    Electrician---Can I have a drum of 10mm earth wire please.
    Wholesaler---How many drums would you like Sir.
    PhilSo and Dr Bodgit like this.
  9. JP.
    JP. Screwfix Select
    Nice 1 Dobbs..:)
  10. Dr Bodgit
    Earth bonding to us mortals.
  11. Risteard
    Yes, although that doesn't stop it being a bonding conductor. It's actually called main protective bonding. The term main equipotential bonding went out with the 16th Edition and EEBAD.
  12. Risteard
    No, that's just completely wrong.
  13. Risteard
    You could just ask for 10mm^2 green/yellow. That's what I do.
  14. spinlondon
    spinlondon Well-Known Member
    Or 10mm Earth.
  15. Dr Bodgit
    Well it can't be completely wrong, as the cable is bonding pipes n whatever to earth.
  16. spinlondon
    Surely it should be completely incorrect?
  17. Dr Bodgit
    Technically speaking, its either correct and right, or incorrect and wrong. It can't be half right/correct or half wrong/incorrect :p
    Depends how you're measuring correctness though...if its ability to understand the meaning being conveyed, then I'd say its good enough! :p:p
  18. dobbie
    Was calling it earth wire when it was green,still called it earth wire when it changed to green and yellow.
    In fact I still call earth sleeving, green sleeving and no one bats an eyelid.
  19. spinlondon
    That’s not quite right.
  20. spinlondon
    You’re showing your age there, been decades since Greensleeves was in the charts.
    dobbie likes this.
