Gas Pipe Earth Bonding
Discussion in 'Electricians' Talk' started by Andrew Banks, Jan 22, 2023.
  1. Andrew Banks
    Andrew Banks New Member
    Hi
    I have just been taking photos of my gas meter for a home car charge installation, and it appears my new build developer forgot to connect the earth bonding 8 years ago!
    The cable is there, but hanging loose. Is this as easy as connecting it to the correct metal gas pipe myself - and if so which one? Or, is it a case of more professional help is needed?
    [​IMG]
  2. eric the fish
    eric the fish Member
    It looks like the clamp is still connected to the earth wire
    Just release the thin metal strap by removing the securing screw ( not the one on the wire)
    Pull out the thin strap,straighten the end with pliers
    Place strap around the copper pipe into your house
    Re thread ,the strap under the fixing screw and get it as tight as possible then screw down the fixing screw
  3. Andrew Banks
    Excellent - thanks eric!
  4. bright_Spark
    bright_Spark Screwfix Select
    Of course it as simple as that to connect the earth to the gas pipe. Now the bit more complicated part is to verify that this earth wire is actually connected to earth and is continuous back to your board or met. It may actually end up being a loose piece of wire cut at a few feet connected to nothing,
    rogerk101 and Ind spark like this.
  5. pppmacca43
    pppmacca43 Screwfix Select
    If property is only 8 years old and incoming gas is plastic, does it actually need to be earthed. My understanding is it doesn’t. Obviously the OPs incoming gas needs to be poly but probably in likely it isnt in an 8 yr old house.
  6. bright_Spark
    That is correct providing you can verify that the incomming supply pipe is plastic, no need to bond the gas in this case. My question would be why is the bonding conductor already there?
    pppmacca43 likes this.
  7. halalooyer
    halalooyer New Member
    There isn't a house in the uk with an incoming plastic gas main
    Coloumb likes this.
  8. bright_Spark
    PVC then if you want to be padantic. It is still a plastic to be correct. So stick that in your pipe!!
  9. Ind spark
    Ind spark Screwfix Select
    bright_Spark likes this.
  10. halalooyer
    If you're going to be pedantic (note the spelling) be correct. PVC is type of plastic, It is not used for gas pipes, and houses don't have incoming plastic gas mains.
    Coloumb likes this.
  11. bright_Spark
    Dont tell me, I am guessing that you are a painter?
  12. bright_Spark
    I think it makes a bold statement that reflects my personality and my standing within society.
    Ind spark likes this.
  13. halalooyer
    OK I won't
  14. bright_Spark
    Thank you
  15. techie
    techie Screwfix Select
    Lol…
  16. pppmacca43
    Mdpe - Medium density poly ethylene
    poly ethelyne is a thermoplastic polymer.
  17. pppmacca43
    Yes, there is!
    Ind spark and bright_Spark like this.
  18. bright_Spark
    Thank god someone else knows their stuff on here and it isnt just me.
  19. Philip Hyde
    Philip Hyde Screwfix Select
    Thought they use Either MDPE or Flexigas corrugated steel pipe. (Still yellow in colour)
    bright_Spark and pppmacca43 like this.
  20. bright_Spark
    They do mate but its obviously not comon knowledge amongst electricians and painters
    pppmacca43, Ind spark and Philip Hyde like this.
