gassafe
Discussion in 'Engineers' Talk' started by kkss, Nov 26, 2019.
  1. kkss
    kkss New Member
    hi anyone had to attend a gas safe inspection event?
  2. kkss
    kkss New Member
    waste of time forum
  3. peter palmer
    peter palmer Well-Known Member
    Not that I have a clue what a gas safe inspection event is but if you wanted an answer why didn't you post it in the plumbing forum where there was half a chance someone would understand the question.
  4. kkss
    kkss New Member
  5. jonathanc
    jonathanc Active Member
    And describing the forum as a waste of time is hardly going to encourage anyone to be helpful is it!
  6. kkss
    kkss New Member
  7. DIYDave.
    DIYDave. Well-Known Member
    Maybe the guys that are suitably qualified to answer this question are too busy as they’re attending a Gas Safe Inspection Event ?:)
  8. WillyEckerslike
    Hi kkss. I assume you're smarting because we haven't all dropped what we're doing and answered your question. I haven't had to attend a gas safe inspection event - and nor has my wife.
  9. dobbie
    dobbie Well-Known Member
    Everyone has been too busy, after the event of inspecting your work, there is a rush on to get it all your work repaired, get it gas safe and safe for gas.
  10. kkss
    kkss New Member
    Check your grammer
  11. dobbie
    Check your spelling.
    WillyEckerslike likes this.
  12. kkss
    kkss New Member
    Sorry love to chat but got a life to carry on with
  13. terrymac
    terrymac Well-Known Member
    Grammer's OK ,but grandad came home pisd from the gas safe inspection event.
  14. kkss
    kkss New Member
  15. jonathanc
    Oh well I’ll try to be helpful and answer the original question
    yes I have had to attend a gassafe inspection event. The event was about 6 months ago at a property I own. It consisted of a mate of mine carrying out a gassafe inspection on a gas boiler. It was a quite unusual event as well because at the same time the same person connected up a 16mm2 to a new CU and completed the installation.
    so the gassafe event was also an electrical event too
  16. Sparkielev
    Sparkielev Well-Known Member
    Plenty of gas coming from the OP though, probably not odourless as well
  17. dobbie
    What type of 16mm2 did he connect up. Was it 16mm swa, 16mm pyro, 16mm t&e, 16mm tails or maybe a 16mm main earth wire to the m.e.t.
  18. jonathanc
    Swa. Sorry should have said!
