Geberit duofix wall hung height and fixings and flush shut off
Discussion in 'Plumbers' Talk' started by baracus, Aug 15, 2018.
  1. baracus
    baracus Member
    Hello,
    Some information on fitting Geberit wall hung frames (duofix)
    1) How do you determine what height to set the frame at? There is a 1m mark on the frame but this differs from the bolt centres height given by the toilet insturctions ( DURAVIT)?
    2) How many fixings come with the duofix kit? I can only see the 2 fixings going down at the bottom of the legs and the 2 fixings going back at the top of the frame. Does the kit come with some side fixings? I can see that the frame has some holes for side fixings but none have been used.
    3) I read somewhere that the flush shut off valve shout be mounted so that the outlet is positioned at the 8 o clock position, is this true? What is the reason for this?
    Many thanks
  2. just pumps
    just pumps Screwfix Select
