Glass door thickness
Discussion in 'Carpenters' Talk' started by sjb68, Feb 18, 2021.
  1. sjb68
    sjb68 New Member
    Hi, I'm making some doors which will be double glazed for an outbuilding, timber will be larch, glazing will be 18mm, stiles and top rail will be 95mm and bottom rail 200mm. Finished door size 715 x 1885
    The larch I have ended up thinner than hoped after planing at 43mm thick. Any advice on whether this is thick enough would be appreciated, I'd prefer to go over the top and be sure there won't be any problems if there is any doubt. As a side note I can still make top and bottom rails wider if need be.
