Gloss masonry paint
Discussion in 'Painters' Talk' started by richhand, Aug 4, 2018.
  1. richhand
    richhand Member
    If after a gloss finish on stone (previously painted with matt) since gloss masonry paint is rarely available is it best to varnish over standard masonry paint or use gloss wood/metal paint?
  2. Astramax
    Astramax Well-Known Member
    Either, check out Polyvine Varnishes as they are waterbased and available in gloss, satin or matt. Have glossed exterior rendered window sills using Dulux Weathershield (solvent based) u/coat and gloss many times without any problems but did prime/seal the masonry paint with Zinsser Bullseye 123 prior to the undercoat.
