Hi I am looking for a gas valve that would fit a Glow worm conventional flue boiler 45/60 or a ITT McLaren valve
These are obsolete, but there are other 3/4" multifuntional 24 volt valves available. I assume you've already tested the transformer to make sure you have the correct voltage.
Hi heatyman, thanks for the quick reply, the gas valve is jammed in the pilot position. After I changed the thermocouple. Do you know any valve that would be available or model number I could use.
Is yours 3/4" or 1/2"? There is sure to be a honeywell or SIT that will dothe job. How do you intend to set it up?
