Good old red and black !
Discussion in 'Electricians' Talk' started by andyruss1976, Apr 19, 2007.
  1. andyruss1976
    andyruss1976 New Member
    Hi everyone,
    did a bit of work at a fire alarm companies office that i do some work for.
    just a few local spurs from local sockets to feed some cctv.
    they had me in on day rate and said to just use any materials i could find in the stores.
    got some 2.5 t+e and wired what i needed too.
    come to connecting up and was amazed to find it was "old" colors.
    it was like stepping back in time !
    BRING BACK RED AND BLACK !
    it was great !
    Cheers,
    Andy......................
  2. yeah I agree...bring back those red and black suspenders
  3. Lectrician
    Lectrician Screwfix Select
    I had to re-wire some cabling inside a large refridgeration panel today. Supply is 150amp TP to panel.
    There is a row of fuses, and one had burnt out, causin the adjacent ones to fail also.
    Replaced carriers and fuses, and also replaced any blackened and stiff cabling. Had to order some tri-rated cable.......as the entire panel was wired in RYB, I jokingly asked for some RYB from wholesaler......and got some! dirt cheap! I couldn't see a problem, as it was inside an 'appliace' anyway!
  4. yekraps
    yekraps New Member
    you still can not beat old red & black
