Good wood for shelving
Discussion in 'Carpenters' Talk' started by Tangoman, Sep 2, 2004.
  1. Tangoman
    Tangoman Well-Known Member
    I want some shelving approx 1.5m wide and 30 cm deep.
    Would solid pine from the local timber merchant be a good choice or is it too prone to warping?
    Tango
  2. PowerTool
    PowerTool New Member
    Have always found pine of shelving proportions (18mm or less planed-all-round) prone to "cupping" i.e. the growth rings trying to straighten out,rather than warping along its length.
    Kiln dried timber generally better,but always check for straightness before buying by sighting along its length.
  3. Yoho
    Yoho New Member
    I've used yellow pine - single piece - for similar sizes. No cupping or warping problems, but the wood did shrink a bit.
  4. Yes your local timber merchant should be a good source.
    Ask them to laminate several pieces, rather than try for 1 piece 300mmm wide. Ideally 3 or 4 pieces with the heart side alternating up and down. "normal" 25mm PSE timber is usually finished out between 20 -25mm. You could ask them to machine some thicker stock to finish at 30-35mm, depends what you want the shelves to hold.
    Be prepared for some shrinkage, especially if the house is centrally heated, poss up to 3-4mm.
  5. big all
    big all Screwfix Select
    depend on how you build it
    what its load is going to be
    and what its purpous is
    [is it a book case]
    big all
  6. Tangoman
    Ay, it's for books.
    Last lot of softwood I got was for flooring - 40mm thick boards and they cupped quite a bit.
    Tango
  7. Tangoman
    They are to be supported at either end and in the middle.
    Tango
  8. big all
    your wood comes in approximatly if you get it from
    a wood yard 20mm by 95[4inch]120[5inch]146[6inch]170[7inch]
    assuming you are going to back it with
    7mm t+g cladding you will be ok
    if you laminate together two 7 inch boards for the top
    a 6 and a7inch board for the sides and bottom shelve
    you attach the top sides and bottom shelve together
    with dowels buiscuts or screws with all back edges together
    you then router out a 7mm by 7mm groove for t+ g
    you then insert the shevlves 2x4 inch +5 inch laminated
    you router all components before fitting if you want
    a routerd edge
    so your top is 340 mm your sides are316mm minus 7mm
    for t+g =309 shelves are300
    hey presto
    if you need any more tips just ask
    big all
    shelves are
  9. big all
    ok its as a shelving unit
    your best to laminate
    or another good solution is 9 inch [new scafold boards]
    they are about 40mm although they are sawn they are clean
    selected for minimum twist knots cupping ect
    make a lovely finnish
    big all
  10. big all
    and i forgot to mention you wont easily get
    pine at more than 10 inches
    also if your wood is captive as in a book case
    with a back the wood is held and any tendances
    are kept in check and because i laminate its
    a lot more stable
    big all
  11. Dewy
    Dewy New Member
    For less movement you would be better off joining 2 boards with biscuits making sure that one boards growth rings are the opposite way to the other board.
    When one cups up the other will cup down making it more stable with only half the movement on each board.
  12. dewaltdisney
    dewaltdisney New Member
    Hi Tango,
    There is a weight and span issue to resolve here. I imagine your collection of chemistry books might be a bit heavy so you need to work out the loading and if the span of your shelves will be too great. Sure you can support the middle but this may not look aesthetically pleasing. Weight will bend most timbers over a period of time so getting the support right is important.
    I would definitely rip wider boards and joint them alternating the growth rings as suggested but I would also rout a channel an inch in from the front edge and get some mild steel in to reinforce the shelf. This method means that you do not need T&G backing which might make room decoration options better.
    Of course if the shelves are only for paperbacks then the steel may not be necessary.
    DWD
  13. mof
    mof Member
    Just get some good quality 3/4" ply or blockboard cut into the required width and edge with veneer or timber, job done.
  14. Tangoman
    You're right about the Chem stuff dwd. That little lot are mostly boxed up now - so it's mainly paperbacks.
    I wasn't planning on building full bookcase here. Simply shelves on brackets. For simplicity, the brackets where you have a track fitted vertically to the wall and brackets slot in. From experience these seem to be the most reliable quick fix shelving. A support in the middle will be essential on a 1.5m span.
    Laminating block board sounds like the best plan - can you buy prelaminated blockboard which you just do the end on after cutting to size?
    Tango
  15. big all
    wicks do timbaboard[laminated]
    600 xabout1800!! by18mm about £27
    or it was about 5 years ago
    so thats 2 shelves a lengh
    big all
  16. big all
    another point
    its worth considering graduating the shelves
    as small books will disappear on large high shelves
    and aesthetically looks less warehouse and more domestic
    big all
