Grab Rail into Plaster Board
Discussion in 'Builders' Talk' started by Sass, Nov 29, 2019.
  1. Multiskillmaster
    Multiskillmaster New Member
    Clean existing with decent cleaning wipes, degrease/clean. Sheet of 15mm or 18mm WBP ply attached to the existing tile with a polymer sealant “s” the entire back of the board (soudal 20 min fix all turbo is my go to...you will not get it off.) stick it in place...tile bead the top and exposed edges...tile whole board..grout, seal to bath etc...fix any handle.. if in doubt ..you could even drill through new, ply and existing tiles and plug and screw ...no one will pull that off!
