Granite worktop width
Discussion in 'Kitchen Fitters' Talk' started by Pikerray, Jan 9, 2009.
  1. Pikerray
    Pikerray Member
    I am having a breakfast bar with granite worktop my question is can I get 1100mm width without having a seam along it's length.
    I will have units back to back 600 floor against 300mm floor unit making a total of 900mm with a 200mm overhang so we can sit on stools at the breakfast bar.
  2. blueassedfly!
    blueassedfly! New Member
    cant see it being an issue as slab granite is approx 2400mm wide when its first cut, i would expect it to be a special order item so therefore wouldnt have a clue how much you may end up paying! ;)
  3. jasonb
    jasonb New Member
    No problem with that unless its over about 3200lg. I just finished one with an island 1100x1600
    Jason
  4. evo nut
    evo nut New Member
    Nice Work Jason, bet it wasn't cheap!
    evo nut
  5. Binfield Carpenter
    Binfield Carpenter New Member
    Looks good .... but the drawers don't seem to close properly!
  6. fooman
    fooman New Member
    it looked better before you started. That green is horrid and that veiw across the base units with there grain makes them all look un aligned.
  7. fooman
    fooman New Member
    pic 10
  8. jasonb
    jasonb New Member
    I'll take that as a compliment as the client specifically wanted mis-matched grain which suited me.
    Jason
  9. fooman
    fooman New Member
