Gravel drive way help
Discussion in 'Landscaping and Outdoors' started by Ramjam258, Sep 29, 2019.
  1. Ramjam258
    Ramjam258 New Member
    Evening all,
    Been in my house 2 years now and want to finally sort out the drive at the rear. It’s a mix currently of a bit of concrete, loose gravel and earth. See pictures.
    My plan was to keep it simple, however not sure if this would work. My plan was to weed the area and lay a membrane and then cover in an inch or so of large gravel.
    The house is in no means my forever home so reluctant to spend lots of money on something that I could sell in 3 years.
    Would this work? Or does anyone have any other ideas.
    Cheers
    B4BED1E0-B50E-4092-B0DA-BFB571F8C3E7.jpeg 443CB2DA-2ACC-4C0D-A31C-FC115A59608F.jpeg
  2. Mark Brister
    Mark Brister Member
    I agree, by far your cheapest option. A bit of Terram membrane and then some shingle/gravel. Don’t put the gravel in too think though, if you use a 10mm gravel I would go about 30mm thick, if you use a 20mm gravel I’d go about 50mm thick.
  3. Mark Brister
    Mark Brister Member
    I would worry about weeding it either, the membrane will kill it once it’s covered.
  4. KIAB
    KIAB Well-Known Member
    One disadvantage with shingle/gravel, it will eventually end up everywhere except on the hardstanding, I would lay concrete, one time job.
    I would say you need around 2 tons at 50mm, & close to 4 tons at 100mm with shingle.
    What size is the area.
    Could use Mixamate or similar, will mix just the amount you need.
  5. sospan
    sospan Well-Known Member
    I you want to put a vehicle on it, a thin layer of chippings will not work. 50mm is about the minimum
    As Kiab says put some concrete down as it will be about the same price, look and last better and would add some value. Assuming the space is 5m x 3m and you want a 100mm thickness, you will need about 1.5 cubic metres about £200.
    KIAB likes this.
  6. KIAB
    Forgot link.
    Quite a few volumetric concrete firms around the UK.
    https://mixamate.co.uk/about/
  7. Astramax
    Astramax Well-Known Member
    Spend a few bob and make it the house to want in the street do as KIAB had suggested, later if you want to improve the parking area further it can have paving slabs laid over or a Tarmac finish.
    KIAB likes this.
  8. KIAB
    I would even render that retaining wall, could easily pour a concrete coping as well,(cheaper than buy copings) when laying concrete slab.
    Astramax likes this.
  9. Astramax
    And offer to paint the neighbours garage walls either side to brighten them up.
    KIAB likes this.
  10. masterdiy
    masterdiy Active Member
    I was reading this tread and thought,.... why hasn't Ramjam258 replied & commented on the reply's he has received??
    Is it because he hasn't turned on Watch Thread??
  11. Ramjam258
    Sorry I have seen all these. Every time I go to reply I get distracted by the little ones or dog and never get back. This time I’m at work and have no distractions .
    If I put I go down the concrete path would I need to add drainage of some sort? Or could you slope it ever so slightly to allow for run off.
  12. masterdiy
    Hi Ramjam258. Good to hear from you. :)
    Yes concrete the lot, & a gentle slope towards the road.
    Hopefully concreting will hide that awful garage floor edge too.
    KIAB likes this.
  13. Ramjam258
    It’s terrible I know, parking my car in the space I always cringe hoping my mrs doesn’t ding the door on it
