How old is the installation?
Guess and let us know.
Does you house suffer with damp?
I notice you say 'sockets' is there more than one with this problem?
There has been a trend towards using a 'lubricant' in electrical terms for getting cables into conduits, this could also be the problem.
The easiest way to check.....
Plug a lamp into the socket in question and turn both lamp and socket ON (So the lamp is on), go to the fuseboard and extract the fuse that makes the lamp go off.
Return to the socket and remove the faceplate fixing screws.
Pull the socket gently away from the back box, the cables should be connected into terminals on the rear of the face plate.
Technical bit now... have a 'butchers' at the condition of the back of the socket, if it's pretty clean, then the previous post is probably right. Eather way, the best option is to replace the face plate with a new one.
The red cables go in the 'L' terminal, the black cables in the 'N' terminal and the Green/yellow Earth cable, or plain copper cables, go in the 'E' terminal.
Refix the faceplate with the old fixing screws, at some time in the past they changed from imperial to metric threads, so best use the old screws, having gently pushed the socket back into position, making sure not to trap the cables with the face plate, or the fixing lugs.
Plug the lamp back in and replace the fuse...
All should now be well.
One other bit of free advice, have a look about at the different sockets, noting the quality of build. 'MK' is a brand name and they are pretty OK, some of the imported sockets are a bit naff.
Need any more help? Just ask.
