Greenhouse Earthing
Discussion in 'Electricians' Talk' started by George Icbar, Oct 15, 2003.
  1. George Icbar
    George Icbar New Member
    I'm putting power into the greenhouse - aluminium framed. What sort of earthing arrangements do I need to make taking into account the mains voltage and lightning strikes (however small the chances are)? Can I just earth it back to the consumer unit indoors or should I use an earth rod in the garden?
  2. Brightspark
    Brightspark New Member
    what sort of power will you be using e.g sockets or just lighting?? will you be fitting a fuse board?
  3. George Icbar
    I'm using IP66 sockets protected by a 16A RCBO. No lighting.
  4. Brightspark
    The socket outlet your using is spot on. There is no need to bond the green house.
    The general rules for protection against indirect conduct only apply indoors, where exposed-conductive -parts and extraneous-conductive-parts are within the equipotential zone.
    Exposed meaning a conductive part of an electrical installation which may become live under fault conditions.
    Extraneous meaning a conductive part liable to introduce a potential and not forming part of the installation. Hope this helps.
  5. George Icbar
    Thanks - didn't want to blow myself up watering the tomatoes.
  6. What about TNC-S
  7. sinewave
    sinewave Screwfix Select
    Drop a Rod in and bond the Frame to it.
    It'll only cost yer £16 or so.
  8. Rabbit Rabbit
    Rabbit Rabbit New Member
    installation.
    Such as an Aluminium framed greenhouse with IP rated sockets INSIDE it ;)
