gren on gas copper pipe
Discussion in 'Engineers' Talk' started by lady_new_2_diy, May 7, 2018.
  1. Hi Sorry for all the posts i figured i best post the problems on separate posts to avoid mix up.
    I noticed green on my copper pipe which carries gas and am a bit worried about it, here is a photo, is it a problem?
    The photo does not show the green very much-loks like grey on photo but is actually green, its a lot more greener when you look at the actual pipe, its in the boiler cupboard, is it anything to worry about?
  2. Astramax
    Astramax Well-Known Member
    Stop worrying would be good advice! :)
    facilities likes this.
  3. But its a gas pipe, thats why i am worried, I tried googling and could find nothing.
  4. Astramax
    No need to worry then, you did the same last year with plumbing posts.....me thinks you are looking for non existent problems! ;)
  5. It's cos the old owner was a cowboy builder who messed around with the pipes and one water pipe did leak a couople of years ago, and cos i live in a flat with a false timber ceiling I worry about rotting the timber above thier plasterboard, but i know that isnt a gas engineer issue.
  6. It's not at all a big issue it can be removed.
  7. Dr Bodgit
    Dr Bodgit Well-Known Member
    The green is just a bit of tarnishing, doesn't lower the strength of the copper, nothing to worry about.
    lady_new_2_diy likes this.
  8. WillyEckerslike
    Agreed. Anyway, what's the worst that could happen.....?
    Hmmm.........
    PhilSo likes this.
  9. PhilSo
    PhilSo Active Member
    The OP could continue posting.
    :eek::D:eek:
    PhilSo
  10. facilities
    facilities Well-Known Member
    Oh noooooo, now she’ll be back :(
    PhilSo likes this.
  11. Bob Rathbone
    The green stuff is copper oxide, a thin layer of tarnish on the pipe surface that will continue to grow and cover the whole surface of the pipe. The green tarnish will protect the copper from further oxidisation but, if you are so minded, you may polish the pipe with ant brand of metal polish, if you have nothing else filling your day.
    Astramax likes this.
  12. Astramax
    Brings back memories of the highly polished copper pipework in public urinals................those were the days people had pride in there work. :)
  13. facilities
  14. Astramax
    Those copper pipes didn't have chance to go green being so well polished even covered in pee made no difference.
  15. facilities
    I’ve seen some installations where the copper is on show and they have been made a feature and clear varnished
  16. Sorry for not being here for a while I wanted to stay away so I didnt pester anyone with more worries, thanks for your replies. much appreciated.
