HI guys - recently installed a new shower with 2 tiled walls over tanked hardiebacker stud walls.
Getting a bit of trouble with water egress to both corners, I've reapplied the sealant around the tray and fairly confident it's not that. I've noticed the grout lines between the tiles go very dark when they're wet and I'm wondering whether it's allowing water through, down the waterproofing behind the tiles and out along the top of the tray.
I used Mapei flexible wall & floor grout (Not the ultra stuff) says it's fine for showers but I spoke to the mapei technical people and they said that it sounds like water is getting through the grout lines and they need sealing - does anyone have any similar experiences and can recommend a good sealer? I'm wondering whether raking it out and using epoxy is just easier in the long run
Cheers!
Cheers!
