Grouting slate floor tiles
Discussion in 'Tilers' Talk' started by countdown, May 19, 2005.
  1. countdown
    countdown New Member
    Can somebody tell me the best way to do this?
    For ceramics, I normally wipe the grout all over the tiles to stop any "picture framing", but looking at the slates, with all those edges, I think this method will leave grout in all the nooks and crannies in the salate surface. I plan to use Arduflex grout, and BAL Fastflex (slates on over boarded hall floor).
    Thanks
  2. britishblue
    britishblue New Member
    Mudster is the expert on this, but I seem to remember reading that you should seal the slate first, before grouting, or you will not be able to clean the grout off the surface.
    BB
  3. countdown
    Hi BB
    Thanks for the reply.
    I have sealed all the slates with Lithofin, and they are drying in the garage at the moment.
    I was wondering if you kind of point them with grout to overcome getting grout in the nicks? or does the grout wash off as with ceramics?
  4. jasonb
    jasonb New Member
    If the slates have a very riven surface I tend to use a pointing method rather than a grout float. The grout will still clean off the sealed stone but it takes a bit more work to get all the grout out of the nooks & cranies.
    Make sure you have flexible adhesives & grout, wide joint if the gaps are over 5mm wide and deep.
    Jason
  5. countdown -As Jason says, you can point them with trowel if they are rough cut riven slates natural, or if they are machined then use your grouting float, either way pay attention to where the excess grout is going & remove with a damp sponge prior to final clean, when fully dry 24hrs min. apply sealer to whole floor incl.grout. Remember to apply the sealer with a fine roller and roll horizontally and vertically on each coat, as you'll achieve an even finish throughout, as opposed to applying say just horizontally twice, as when you lay them, you may end up with a chequerboard effect in certain lights. :)
  6. countdown
    Thanks chaps.
  7. JS3500
    JS3500 New Member
    Have you thought of liquid grout ? Can't for the life of me remember the name of the stuff but basically pour it into the gaps, finds it's own level - job done.
    Used it years ago on a slate floor with good results.
  8. countdown - with respect here's a conundrum for you, ref the above "liquid grout"
    ------------L----O----L---O---X----B----
    hope that helped m8 :)
  9. Washboy
    Washboy New Member
    Not so fast - I came across 'liquid' grout , if thats the word, in france and Spain. I think it was basicly very watery grout, almost as runny as slc. May have had something to do with the heat. Not sure i'd want to use it on riven slate though; I think a stiffer, drier mix would be easier. or a grouting gun - but not too fond of them..
  10. Washboy
    Washboy New Member
    By the way - never have come across 'picture framing' with cermaics. You sure about that??
  11. countdown
    Picture framing was mentioned when I did a training course with Ardex.
    Anyway, laid and grouted up using a stiffer than normal grout (Ardex FL wide joint) and made sure I washed each slate very carefully. Job done and if I say it myself, looks rather good!!
    Thanks for guidance and input.
  12. bathstyle
    bathstyle Active Member
    OK M3, you've kept us waiting long enough! please reveal todays conundrum.
  13. don't be silly, you know it really bstyle, you're just trying to get my thread moderated "xollob" backwards :)
  14. bathstyle
    I'll be tuning in next week for another conundrum!!
  15. Consonant please Carol
  16. Ok here we go:
    ST*A*N*E*LA
  17. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    Are the gaps a clue ?
    Mr. Handyandy - really
  18. Mr. Handyandy
    Is this a real word ? Or is it a con ?
    If it is, that's silly !
  19. real word...
    cryptic clue - water dog had the power many more times his own weight..............???
