Grundfos TF110 blowing fuse
Discussion in 'Plumbers' Talk' started by Knowsome, Nov 2, 2018.
  1. dobbie
    dobbie Well-Known Member
    Is the system gravity hot water and pumped central heating?
  2. Knowsome
    Knowsome Member
    Don't know. Why?
  3. Knowsome
    Knowsome Member
    I found that the resistance of the pump was 200 k ohms L to N where I was expected 200-250 ohms. And the pump blew the fuse. I bought an Alpha 2L and the system works fine now, although it took a long time to clear itself of airlocks. The Alpha 2L has a clever plug to connect it but which only takes solid core no flexes so I had to replace the flex lead. Thanks to everyone who contributed to this forum thread.
  4. terrymac
    terrymac Well-Known Member
    Cheers for letting us know , glad your sorted.
  5. Pollowick
    Pollowick Well-Known Member
    Are you sure? Mine is certainly connected with multistrand flex. You insert it into the hole then push the "button" down to lock it in.
    Knowsome likes this.
  6. Knowsome
    Knowsome Member
    It seems I have missed something. There were illustrations but I didn't notice any "buttons". Thanks for that info!
  7. Pollowick
    Button may be the wrong word but cannot think of an alternate. They are just maybe 2mm diameter and push down to grip the multistrand - unless there is a newer version.
  8. Knowsome
    Knowsome Member
    Thanks Pollowick at present the pressure from the cable retension is holding the wiring in place as all I did was push the casble in. Be over to the house tomorrow to check it out.
  9. Pollowick
    Point 4, shows them being screwed in, although I am sure others have a different type of final fix.
  10. Knowsome
    Knowsome Member
    Thanks for the excellent graphics Pollowick. I still have not inspected the plug but the CH system is working fine now.
