GU10 LED colours
Discussion in 'Electricians' Talk' started by robertpstubbs, Dec 6, 2018.
  1. robertpstubbs
    robertpstubbs Active Member
    I have some outdoor GU10 spots where I want a gentle light. I have tried white LEDs which are harsh and yellow LEDs which are dull. Does anywhere sell anything in between?
  2. Pollowick
    Pollowick Well-Known Member
    What are the colour temperatures of those you have tried?
    2500, 2700, 3000, 3500, 4000, 5000, 6000
  3. rogerk101
    rogerk101 Well-Known Member
    I have tried more GU10 LEDs than I care to remember and the only ones that I find really good are warm white Philips 10W dimmables.
  4. robertpstubbs
    I can’t find the temps but I think the whites are around 3000-4000K.
    Where do you get 2500Ks?
  5. KIAB
    KIAB Well-Known Member
  6. robertpstubbs
    The Sunset dimmables look interesting.
    I haven't used dimmers recently. Would the dimmer be additional to the 2-way and intermediate switching:
  7. robertpstubbs
    Or can the dimmer replace one of the 2-way switches?
  8. robertpstubbs
    I’m lighting outdoor paths etc, mainly from wall mounted lights.
    I chose GU10s partly because of the wide range of lamp colours/wattages/angles available, but haven’t found the right ones yet.
    Also I thought that GU10 spots would allow me to point the light exactly where I want it, but have found that this often directs it in one’s eyes.
    The GU10s are connected into the load part of lighting circuits via Wiskas, so could easily be replaced with alternative types if necessary.
  9. Bazza
    Bazza Well-Known Member
    Yes, one of them, unless you go for a special type that allows multiple dimmers.
  10. robertpstubbs
    Thinking about it I probably can’t use dimmers as I also neon indicators for each group of lights.
    I have recently tried:
    Meridian 2.5W 3000k 120deg.beam £1.40ea
    Philips 3.5W 2700k 36deg.beam £2.98ea
    The Philips actually seems have exactly the same wide beam angle as the Meridian, and the overall light output of the two types seems very similar despite their different specs.
