hi I am abpout to put up some guttering round a summer house and a fall pipe into a water butt anything i should watch out for
> next door's daughter sub bathing? yeah sub bathing is great...you gotta be quick tho when the captain shouts 'dive dive dive'
no its easy. gradient of 1mm for every 600mm, clip every metre (maximum). make sure you cut gutter to expansion line, not the stops, or it'll buckle n bow when its hot. over shoot the ends by 50mm and thats about it.
tooltarticus gradient of 1mm for every 600mm, clip every metre (maximum). lol i take your not a time served plumber. 4mm fall every metre 12mm over a 3m length.
kiss my bender fool. damn straight im time served, and i'm quoting figures etched into my brain from my college days, incidentally , where I was top boy.these figures have served me well ever since and have never had a call back to guttering jobs. ever.
U guys argue over the guttering 'techniques' and I'll be over next door 'Over shooting by 50mm' the babe in the Bikini!
things change from the stone age and you have to change with it. im afraid. Go Screwfix yourself. You assume too much, and know too little. The gradient you prescribe was fine when installing asbestos and cast due to the greater frictional resistance, I would imagine , although I'd have to defer to you on that, grandpa, as I wasn't around prior to the Great War. However, I commend you on evidently having made the leap from Imperial to Metric, ol'Timer.
Why is everyone trying to make gutters sound so technical?! Hell, if the water runs down the hole and into the drain it's sorted,gradiants my ****!!!! tooltarticus,you're a dick!!!!!
Hell, if the water runs down the hole and into the drain it's sorted,gradiants my ****!!!! and if the water doesn't run down the hole and into the drain, and spills over the side of the gutter, and grows moss etc etc.........you haven't put the correct gradient on..
Why is everyone trying to make gutters sound so technical?! Hell, if the water runs down the hole and into the drain it's sorted,gradiants my ****!!!! tooltarticus,you're a dick!!!!! Clearly makes me twice as usefull as you then sir
