Handrails to post fix .
Discussion in 'Getting Started FAQ' started by Papajoe, May 4, 2018.
  1. Papajoe
    Papajoe New Member
    Hi, I am in the process of putting 4x4 oak posts onto our patio. Could anyone advise me of the best way to attach the oak 4x2 handrails.
  2. Wayners
    Wayners Well-Known Member
    Get some 25mm round dowel. Drill a 25mm hole in rail end and post and glue with the inserted dowel.
    KIAB likes this.
  3. Papajoe
    Papajoe New Member
    Thanks for your reply Wayners. I will try that and let you know how I get on.
  4. bodgitt&scarper
    bodgitt&scarper New Member
    You could also use a plug cutter and some screws. Remember oak is corrosive to steel, so passivated and a decent guage screw would be best. You may also end up with staining, so a dowel might be the best option.
  5. Astramax
    Astramax Well-Known Member
    Look on You Tube, plenty of video's and differing techniques that may help you decide what is suited to your requirements.;)
  6. KIAB
    KIAB Well-Known Member
    Seen brass dowels used in the past.
