Hanging 4 Doors - Need help with ordering correct sizes.
Discussion in 'Carpenters' Talk' started by Chrissy M 72, Aug 2, 2021.
Tags:
  1. Chrissy M 72
    Chrissy M 72 New Member
  2. jonathanc
    jonathanc Screwfix Select
    Think you’ll struggle with the top two… only got 2cm either side to trim so you’ll be very thin on the sides
  3. Chrissy M 72
    What do you suggest the 4 sizes of doors I order? I’m ordering them and a joiner is fitting them btw.
    Thanks
  4. techie
    techie Active Member
    Let the joiner order them….
  5. jonathanc
    You need to find a door that can be trimmed sufficiently to fit. Keep searching for different suppliers
  6. Jord86
    Jord86 Screwfix Select
    Get the top two doors in metric size of 2040x826 and plane/cut them down, and get the other two doors in imperial sizes 1981x838 or a 33 inch/2'9" door.
