Hanging lining paper
Discussion in 'Painters' Talk' started by stealthwolf, Mar 7, 2019.
  1. stealthwolf
    stealthwolf New Member
    Bedroom is being redecorated. Layers of old wallpaper have been removed. I've filled any holes and patches with ronseal wall filler and sanded them down. The plan is to line the walls with lining paper and then paint over. I've pored over forums but still don't have enough information and I've never hung wallpaper before!
    Questions:
    1. What grade lining paper? 1200-1400 seems usual.
    2, Do I still need to size the walls with wallpaper paste (and allow to dry for 24 hrs)?
    3. Should I use Zinsser Gardz instead?
    4. Is Erfurt Fibreliner overkill? Should I stick to standard liner paper?
    5. Do I need to thin the first coat of paint?
  2. Astramax
    Astramax Well-Known Member
    1, As you have not hung paper before you may find the 1400 a little more demanding, if the walls have been prepared well 1200 grade will be fine.
    2, Yes.
    3, Extra expense.
    4, Unless your walls have badly crazed plaster it would be overkill and is also a paste the wall product.
    5, Just a little if you see fit, wouldn't hurt.
    WillyEckerslike and stealthwolf like this.
  3. Wayners
    Wayners Well-Known Member
    Wallrock is good stuff and easy to hang but costs more. Roll on some thin paste to seal day before then I spray water with garden sprayer prior to lining walls to liven it up a little.. I'd go with standard lining paper and see how it goes. It's not difficult and you only learn by having ago. Thinner 1200 will be fine. So many ideas and ways to do it so don't get bogged down with the details. Just have ago and learn as you go . Your way
    stealthwolf likes this.
  4. stealthwolf
    Went reasonably well. 1400 lining paper. Wasn't too difficult to use. Walls were sized beforehand.
    I got mostly good butt joints with the drops but a few gaps on a couple of drops, less than 1mm and not the full length of the drop.
    Is paint, fill, sand, paint a good plan?
    Any particular filler that's recommended? I've heard some can cause problems with the dried paste, or can flash or grin through subsequent paint layers.
  5. DIYDave.
    DIYDave. Well-Known Member
    Toupret Interior Filler v good
    Available as 2kg box (powder) from our hosts, T.Stn, etc
  6. Astramax
    Paint with 1st coat of emulsion, when dry use Easifill to blind the joins.
  7. b4xtr
    b4xtr Active Member
    Out of interest, what's peoples view on if lining paper should be applied horizontal or vertical ?
    Seem to remember someone advised, not on here, that it should be horizontal ?
  8. Astramax
    Can do either way but horizontal preferred if cross lining.
    b4xtr and stealthwolf like this.
  9. stealthwolf
    Everywhere I’ve read recommends crosslining if papering over (ie horizontally) to avoid seams overlapping, and vertically if painting (which is what I’ve done).
    b4xtr likes this.
