Hatchet job?
Discussion in 'Plumbers' Talk' started by white rabbit, Jul 22, 2019.
  1. white rabbit
    white rabbit Member
    Hi all,
    Just recently had a new kitchen fitted, including plumbing work to install new dishwasher, sink and washing machine.
    The plumbing work to connect all three to water mains and waste pipe looks pretty crazy (see photos) and I've noticed a bit of a smell constantly around the sink area.
    I'd really appreciate some feedback on this as I'm thinking the smell is likely caused by the way the plumbing has been configured under the sink.
    Would be great to get your thoughts!
  2. just pumps
    just pumps Well-Known Member
    Only looking on the phone screen mind, but the bigger pipe to the left is the outlet and is running uphill! Does the sink actually drain like it should?
  3. masterdiy
    masterdiy Well-Known Member
    JP, yes it does look like that.
    I would think that could be the cause??
    It looks like the dishwasher & wash machine waste not getting away.
    White rabbit, get the plumber back & say its not been fitted correctly.
  4. Mike83
    Mike83 Well-Known Member
    That flexi waste is terrible.
    The waste shouldn’t run upwards it should be the opposite.
    It will eventually get blocked.
    The waste needs stripped back and redone from a lower level.
  5. just pumps
    Hard to see but is there another white pipe in the top right hand corner above the brown bag behind a silver flexi?
  6. DIYDave.
    DIYDave. Well-Known Member
    Looks like just a reflection, possibly from flash when taking picture
    But yep, look quickly and it ‘may’ look like a 40mm waste pipe !
    All that gunge from waste water gonna be getting caught in those folds of the flexi pipe
    Guess just easier / quicker / cheaper / than coring a new hole through wall lower down
  7. Severntrent
    Severntrent Active Member
    But does any of the above cause the smell, since there is a working ubend probably not?
  8. just pumps
    New discharge water disturbs debris which hasn`t cleared the highest point of the discharge line so yes it does cause the smell.
    Severntrent likes this.
  9. Diyloser
    Diyloser Active Member
    The inlets for the WM & DW are plughole side of the U bend so you could get some smells from the appliances.
  10. koolpc
    koolpc Well-Known Member
    Naff job for sure
  11. The Teach
    The Teach Well-Known Member
    The combined sink drain is badly installed,often the existing sink drain pipe is fitted high but for unknown reasons it is not lowered.Sometimes its not possible to alter that pipe :(
    the new kitchen specifier should have noticed the high drain pipe and specified a sink with a more shallow bowl and if necessary omit the dual appliance drain spigot,then install a section of 40mm rigid pipe with a slight gravity fall where the appliance spigots can be connected :)
    There again the smell could be a dead rat :D
  12. white rabbit
    white rabbit Member
    Thanks everyone for the feedback, much appreciated!
    I've added some more photos in case that sheds some more light around how it was installed.
    Is it going to be relatively straightforward to fix?
  13. Peter208
    Peter208 Active Member
    I don't like the look of the flexable with the White tape on it, it appears stressed and will fail, should have used a longer flexible. Why did he fit a flexable drain pipe, never the best idea.
  14. The Teach
    yes :)
  15. DIY0001
    DIY0001 Active Member
    Both of those braided flexi-pipes are going to fail prematurely. They need to be replaced (and the originals dumped) asap since they have clearly been damaged during fitting and are flexing much too close to the connector. The damage caused by a burst flexi can be more expensive to fix than getting this bodge properly sorted.
  16. Severntrent
    So filling sink with water each evening and pulling plug should clear this mysterious decaying debris and prevent smell?
  17. Severntrent
    As are everyone's wm and dw connections who don't get smells. If they were after the ubend you would then get sewer smells.
  18. just pumps
    Would certainly help and nothing mysterious about debris found in kitchen sink pipework set up like that. You sound like most of your work is external to buildings.
  19. white rabbit
    white rabbit Member
    Thanks again folks for the feedback.
    Regarding the smells, I've checked it out a bit more and can confirm no smell is coming up through the plug hole at all, perfectly fine.
    Seems the smell seems to originate from under the sink, most likely where the pipework is coming in/out of the cabinet that houses the sink.
    Any ideas what might be going on?
  20. Astramax
    Astramax Well-Known Member
    Waste pipe maybe has become disconnected under floor letting by drain smells.
