Have I been given an out of date tin of wood filler
Discussion in 'Screwfix' started by lemonade, Jan 13, 2019.
  1. lemonade
    lemonade Member
    I bought a tin of ronseal wood filler back in march last year and on the bottom of the tin it says 18/12/D. I opened the tin today and the consistency is like chewing gum and by the time I mixed it up it started going off.
  2. Astramax
    Astramax Well-Known Member
    Is it the Ronseal 2 part epoxy wood filler, if so it can't go off until the hardener has been mixed in. So could be just out of date (Dec 18).
  3. goldenboy
    goldenboy Well-Known Member
    How much of it did you mix up?
    I watched a bloke try to mix a whole tin up in one go.
    Didn't go well.
    Fillers do go off when air gets to them.
    I use quite a bit of 2 pack and once they have been opened you get about a year or so before it deteriorates.
    Did you open it up when you bought it? Or did you use a bit?
  4. lemonade
    lemonade Member
    Yes it's ronseal 2 part epoxy wood filler. Either I had a blond moment or the fumes got to my head as I was thinking the date was 18/2012.
  5. lemonade
    lemonade Member
    I mixed up just under a golf ball size and it went off in under 5 minutes so I mixed up maybe a teaspoon size and that went off within 5 minutes. I haven't used any out of the tin in the past but I cannot remember if I opened the tin when I bought it. I watched a ronseal video and when they mixed the filler up you could see the filler going off while he was mixing it. If I was to buy new filler what brand would you recommend.
  6. Peter208
    Peter208 Active Member
    Just on the subject of wood filler, I got a small pot of Ronseal yesterday . It says LIGHT as a colour indicator . No way is it Light, it's quite terracotta / reddish brown. I expect better then that from Ronseal, and now hope it does what it say on the pot.
  7. goldenboy
    Thats normal. You need to work fast with two pack.
    Quick mix, quick application.
    Ronseal one is pretty good in my experience.
  8. DIYDave.
    DIYDave. Well-Known Member
    The Ronseal 2 part filler is a great product but does suffer from prolonged storage which does speed up its workable time. Also replace lid ASAP after using, contact with the air will shorten its life
    If your getting around 5 minutes usable time, then that’s not so bad as even with a new fresh tin, you only get maybe 10 mins until it starts to stiffen and then sets rapidly
    As with all of these 2 part fillers, only mix up small quantities at a time and work fast with the filler, have work area ready to fill before mixing up and start and finish filling without stopping
    Never use a scrapper or tool with old filler on it and put back into tin, you will shorten its usable time, same as mixing, don’t mix fresh batch on surface that you’ve just mixed previous batch, you will greatly shorten usable time
    Clean scrappers and tools between each mix, try and remove excess filler before setting rock hard. Any fully hardened filler can be sanded off of tools then give a rinse, ready for next batch to mix
    I find the Ronseal is fairly easy to sand compared to some other brands and performs very well, as long as you don’t contaminate each mix with old filler and work fast
    As diy’ers, we’re not using this stuff day in and out so towards the end of the tin, if it’s been stuck in garage/shed for months, expect reduced performance
  9. Astramax
    Prefer Decor-Fil myself, even did my car body panels with it. ;)
