Health Faucet
Discussion in 'Plumbers' Talk' started by Pikerray, Jan 25, 2009.
  1. Pikerray
    Pikerray Member
    Has anyone on here plumbed in those Health Faucet contraptions that wash your bum, it's a pull out type small shower unit for cleaning your private parts ?
    I assume they have a hot & cold supply ?
  2. superfurryanimal
    superfurryanimal New Member
    depends which model uve got ....
    [Edited by: admin6]
  3. rome60
    rome60 New Member
    I think the japanese model has a hot air blower also to dry your a--e.:D
  4. ballcockandfloat
    ballcockandfloat New Member
    I had to service one.it was a Aqualisa shower valve fitted near the W.C the hose and handset was long enough to wash your bum after a dump.Some religious thing about not using paper.I still prefer to use a bog brush.
  5. soldering-on
    soldering-on New Member
    What make is it, there are several different types.
  6. doing a bit
    doing a bit New Member
    sounds like a high risk cross contamination issue, shower head falls in the pan ?
  7. ballcockandfloat
    Yeah there was an issue with it falling into the pan but the handset was purpose made with a lever to turn the water on and off with a N.R.V. built in.
