heaters
Discussion in 'Electricians' Talk' started by andyboy, Jan 30, 2004.
  1. andyboy
    andyboy New Member
    Wiring 2 2kw convectors on a circuit, do you think i would get away with a 16a breaker or should i go for a 20 to be on safe side.
  2. Dicky Minton
    Dicky Minton New Member
    Use a 20A MCB, the current for two 2kw heaters is just over 16A.
  3. andyboy
    andyboy New Member
    ok i will stop being tight, and get a 20a, although looking at the time curves the minimum current to trip a 16a breaker is 25a.
  4. Damocles
    Damocles New Member
    might run a bit hot though, don't know if they like that
  5. supersparky
    supersparky New Member
    how do you figure that?
  6. Damocles
    Damocles New Member
    I meant the 16A, they're thermal devices. seem to remember something about not putting fully loaded breakers next to each other because heat build up might cause them to trip below rating
