Help find led replacement bulb
Discussion in 'Electricians' Talk' started by Wayners, Sep 13, 2018.
Tags:
  1. Wayners
    Wayners Well-Known Member
    Hi all...anyone know of an equivalent led bulb to this ses 25watt reflector bulb? It's for a display cabinet and all the ones I've looked at are to long.Thanks [​IMG]
  2. rogerk101
    rogerk101 Well-Known Member
    It's a regular E14 bulb ... plenty of choices available in LED at different power/lumen ratings. Even our hosts stock several choices.
  3. Pollowick
    Pollowick Well-Known Member
    I assume it is an R50, what is the actual length from tip of centre contact to highest point of glass? And how much extra space is there?
  4. KIAB
    KIAB Well-Known Member
    You can get R39 lamps E14 fitting, & 65mm length,39mm diameter compared to 87mm & 51mm diameter for R50 lamp.
    If 25w, then it's a R50, R39 is only in 30w in lamp book I have here.
  5. Wayners
    65mm long tip to end of screw so very short. 38 mm at widest point. D4 25watt is on bulb
  6. KIAB
  7. Wayners
