Hello, This tap is very noisy when I use the toilet, other taps in the house or the shower. Any ideas on how I can fix it? Regards, Daniel
What sound does it make ,clanking ,banging ,drone etc ? And do you mean if that tap is NOT running , you hear a noise from it ,whilst another tap is running ? Or have I totally misunderstood your post ?
Thank you for your message, I should have been more precise. It happens when the other taps, toilet or shower are/is running. The tap is turned off. To be honest, the sound is more like the CO2 alarm going off... 1st time it happened I was on a very cold night- we tought is the neighbour's alarm- so I assume the mains pressure was low and since then every night the temperature drops around 1-2 degrees or lower it does the same... I have noticed that even when the washing machine is taking water it makes a humming noise. Does that make any sense? Regards, Daniel
Are you sure the noise is from the tap ,not your mains stopcock ,that may be below the sink / tap ,or somewhere other in close proximity ? You could have a look under the tap at its supply pipe ,see if you have an isolation valve that isolates that tap. If you do ,isolate the tap and see if the noise is still persisting. If it is ,its not the tap. If its stopped ,change the tap.
I am quite sure it is not from the mains stopcock, I will upload a short video later today. I will isolate the tap like you said, see what happens. I have tried to open it and take the cartridge out but it seems stuck. Better off just changing both taps maybe. Thank you
Ok, your pic in your first post is on the left hand side of the sink.........................let's assume it's the hot tap. The YouTube video is the right hand tap, so should be the cold tap. So maybe it might actually help us to help you if you can tell us what tap is actually causing the issue ?
Hi, I realised that, they are both noisy, the one on the right/cold tap is a lot noisier than the one on the left that's why I choose to have it in the video. The picture was sent by my wife, didn't think it will make a difference.... Thank you, Daniel
seems the tap drips for a while in the off position then drips stop,do both taps do the same ? Any other dripping taps in the property. There may be isolation valves under the sink which could be turned off temporarily and then try other water taps,flush wc and see if noise appears. The noise appears to stop when the drips have stopped,Does your water system have any type of booster pump ? Really needs onsite investigation every property is different,its usually something simple
I see... In the video I flushed the toilet, that is when the noise and the drips started, once the toilet tank was full the noise ceased. The same thing happens during the night when it's cold and the pressure it's low. Both taps are quite the same, the cold one always the noisiest. I do not have a booster pump, the mains feed the bathroom, kitchen and the the last it's the toilet. I only have 2 more taps in the bathroom and they do not drip or make any noise. Thank you
Fit a new pair of taps ,preferably with screw down heads ,rather than ceramic 1/4 turn lever valves. Yours are kaput !!
