Help needed with next step after removing wallpaper
Discussion in 'Painters' Talk' started by Movieman334, May 6, 2018.
  1. Movieman334
    Movieman334 Member
    Hi All,
    I'm trying to remove my wall paper and re do my bedroom, Ive reached the stage as attached pictures show and now I'm not sure what my next step should be.
    Should I plaster or skim.
    Just put new wall paper on
    Do I have to remove every single bit of wallpaper
    Your thoughts would be greatly appreciated
    Thanks
  2. fillyboy
    fillyboy Well-Known Member
    Depends what type off wallpaper is going up. If it's a flat paper with a printed pattern, the walls need skimming, if it's a raised anaglypta, the walls will need at least a bit of filling here and there depending on the thickness of the anaglypta.
  3. Astramax
    Astramax Well-Known Member
    You need to remove all wallpaper and sand all walls back to a smooth surface, filling out areas where required with Easifil and a caulking tool, then sanding smooth when dry would help to achieve a smooth surface and not so involved as a re skim. You do not say what type of wallpaper you will be hanging
  4. Movieman334
    Movieman334 Member
    Thanks gents, Astramax I know you mention to remove ALL the wallpaper is this totally necessary do you think ? as it's a real pain to move as it's been painted over so the steamer struggles to penetrate it properly.
    What I was thinking is I would be able to skim the whole wall as it is, very light layer and then put plain white wallpaper over it and paint it ?
    THanks Filly boy and Astramax
  5. fillyboy
  6. candoabitofmoststuff
    candoabitofmoststuff Active Member
    Yep... it is!
    Regards,
    Cano
  7. Movieman334
    Movieman334 Member
    Thanks gents, i've decided to remove all the wallpaper and give it a good skim :)
  8. CGN
    CGN Well-Known Member
    I'd give it a good sugar soaping to get rid of the paste residue etc. If you want belt and braces approach, then blue grit before skimming. Skimming is the way to go though.
    Longy75 likes this.
