HELP- Old door frame is 860mm, I cant find a door that fits?
Discussion in 'Carpenters' Talk' started by Chris1004, Sep 3, 2019.
  1. Chris1004
    Chris1004 Member
    I've got to replace 10 doors in a house and replace them with firedoors, The problem is its a old-ish house and i cannot find the correct size firedoors anywhere? The closest i can find would need so much trimming off for example:
    Door frame:
    860mm (W)
    2060mm (H)
    Door from travis perkins:
    826MM (W)
    2040 (H)
    Anyone have any ideas? Many thanks.
  2. WillyEckerslike
    I had a similar job for a HMO. I ended up getting the doors made to order by Jeld Wen - client paid so not my problem. Several of the original doors were thinner though so I had to deepen the rebate on the casings to take the new 44mm doors.
  3. KIAB
    KIAB Super Member
    Plenty of places do bespoke made-to-measure internal fire doors.
