Help - Previous owner drilled hole in uPVC Window
Discussion in 'Builders' Talk' started by Mattm1810, Jan 29, 2020.
  1. Mattm1810
    Mattm1810 New Member
    Hi,
    I've just bought a new house only to notice that the previous owner has drilled holes in the uPVC window frames. Some aren't very deep and were used for blinds I think. However, one in the main bedroom goes right through as they had the great idea to bring a TV cable through that way. Does anyone have any advice for the best way to seal this up?
    Cheers,
    Matt
  2. furious_customer
    furious_customer Screwfix Select
    Silicone?
    Or glue some white screw-head caps over them.
  3. Astramax
    Astramax Super Member
    Look on ebay for hole plugs, blanking plugs and buy the smallest size you can get away with. Drill a small hole that fits the size of plug shaft and simply insert. :)
    Wayners likes this.
