Help stopping a kettle leaking
Discussion in 'Other Trades Talk' started by TaDaScrewFix, Feb 23, 2009.
  1. TaDaScrewFix
    TaDaScrewFix New Member
    Hi!
    My rather nice kettle has sprung a leak around one of the 'windows' on the side. Looking in from the top, its obvious that the leak is due to the gromet/frame around the 'window' coming away from the metal 'wall' of the kettle.
    I'm pretty sure that I can take it apart and get access to the faulty parts and that I could fix the problem with a suitable glue.
    But here's my question what glue can I use to stick plastic to metal that won't degrade when in boiling water and is non-toxic?
  2. gadget man
    gadget man Well-Known Member
    Buy a new kettle you tightwad!
  3. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    High temperature gasket sealer(as used on vehicle engines). Don't ask me if it's food-safe though - £4.99.
    New kettle from Tesco's - £5.99.
    Mr. HandyAndy - Really
  4. TaDaScrewFix
    'gadget man' - No need to be cruel
    Mr Handy Andy - Thanks I'll take a look at the sealants.
    I have my reasons for wanting to fix the kettle. You can choose from a whole range from emotional attachment through environmental concern to sheer bloody mindedness. I didn't come here for abuse - I came here for help and advice.
    Can anyone recommend a suitable sealant?
  5. Mr GrimNasty
    Mr GrimNasty Active Member
    DOW CORNING® 781 Acetoxy Silicone Sealant or equivalent.
    Approved as food safe/potable water contact safe in some countries, highly flexible and temperature extreme resistent. S/Fix have it in at clear and white.
    DIY womble likes this.
  6. TaDaScrewFix
    Thanks Mr GrimNasty.
    Seems ideal - especially since it may only give off noxious fumes etc if above 150 degrees C.
    If a kettle gets above 150 degrees I think I would have vacated the kitchen already :)
  7. nigel
    nigel Guest
    The problems often due to scale build up distorting the seal , a descale may be enough to cure leak.
  8. TaDaScrewFix
    Now there's a thought!
    Looking at the 'frame'/'gromet' it looks like it is split but a descale won't do any harm..
    Thanks
  9. G Brown
    G Brown New Member
    Ditto
  10. TaDaScrewFix
    Yeah! Double ditto!
  11. Mark the Dog
    Mark the Dog New Member
    I had the same problem, an £80.00 kettle 3 months out of warranty Dualit refused to repair or replace.
    My kettle started leaking from the plastic window at the bottom.
    I solved the problem buy Dow Corning 781 silicone it is a food grade product and temperature tolerant, you need someone with small hands, make sure the kettle is perfectly dry, smear the silicone around the edge of the inner seal, dont worry if you get it on the window, wipes of easy with a spot of white spirit.
    The only place i could find the silicone was Screwfix.
    Kettle now perfect again
  12. Astramax
    Astramax Well-Known Member
    Where did you purchase the food grade white spirit from.
  13. Mark the Dog
    no such thing as food grade white spirit, it evaporates, boil the repaired kettle a few times, all is good
