Back again - long story short cant get anyone to install for a few weeks so figured I continuity check the wires to see if I can sort this myself. Ive attached a full key diagram showing all the connections (to refresh the previous owner replaced the standard boiler with combi, removing water tank, etc - I have a Honeywell ST programmer and Salus stat - I would really like to be able to use the existing stat location to wire the nest thermostat to and swap the programmer to the heat link at the same location so will need to use 2 of the 3 stat wires as 12v connections to the heat link. If you need any photos or anything else to explain what I connect to what to make this work please let me know - would really appreciate some guidance on this (assuming its still possible having seen the full wiring plan!
