Help wiring my lights
Discussion in 'Electricians' Talk' started by Jonny89, Aug 13, 2019.
  1. Jonny89
    Jonny89 New Member
    Hi guys,
    I'm just trying to change the lights in my flat and I've come across a little problem.
    The original light has a lot more slots for cables whereas the new one only has three and an extra little separate connector. It's fine for some lights that aren't on a loop but for the others I'm not sure how to wire them up. Can I just put two lives into one slot and two neutrals into one as well, or do I need to wire it differently than that?
    Thanks,
    Jonny
  2. Mike58
    Mike58 Member
    NO!
    Unless you want a big BANG and the resultiung mess.
    Do you have a picture from before you disconnected them? Did one have a sleeve? Is it a single light off one switch?
  3. Jonny89
    Jonny89 New Member
    Thanks for the quick reply Mike, I've attached an image of how it was wired before.
    Its one switch that turns on two lights
  4. dobbie
    dobbie Well-Known Member
    Put the two browns in L the two blues in N and the green and yellow in the middle with the earth sign.
    seneca likes this.
  5. seneca
    seneca Screwfix Select
    Just like it was before!
    dobbie likes this.
  6. Jonny89
    Jonny89 New Member
    Awesome, thanks guys!
