Help wiring thermostat
Discussion in 'Plumbers' Talk' started by Lucas Walker, Aug 14, 2019.
  1. Lucas Walker
    Lucas Walker New Member
    IMG-20190726-WA0000.jpeg IMG-20190726-WA0002.jpeg IMG_20190707_190027.jpg I am trying to replace a Honeywell T6360B with a Flomasta 7593G and need a little guidence.
    First of all, will it work with 2 wire and secondly what goes where, attached above are images of the old and new diagram and also an image of how the old stat was wired.
  2. Hans_25
    Hans_25 Well-Known Member
    Screwfix shows the 7593G as a 3 wire installation
  3. The Teach
    The Teach Well-Known Member
    Not properly,similar heat reaction/fluctuation time as the existing honeywell or even maybe worse :(
    Terminal 1 is the same on both thermostats.
    Is there a spare conductor in the existing cable serving the honeywell room thermostat ?
    TT:D
  4. MGW
    MGW Well-Known Member
    No it will not work, I have only seen one wireless thermostat that works with 2 wires, Nest e is the only one I know of where the receiver is battery powered, and the thermostat is either USB or use a battery base.
    May be there are others, but I have not seen them.
  5. Hans_25
    I have an old Honeywell digital wireless thermostat, runs off a AA battery and needs only 2 wires & has 6 programmable timeslots. Its redundant now as am moving to Drayton Wiser.
