S Scott1706 New Member Jul 25, 2024 #21 Hi any idea where I've gone wrong. I've swapped the transformer out and connected wires up same as old one was and connected the fan up with matching wires Attachments IMG_20240725_192139903.jpg 3.4 MB · Views: 14 IMG_20240725_192054253.jpg 3.3 MB · Views: 15
Refuse to Bend Well-Known Member Jul 25, 2024 #22 Get an electrician involved to fit a new controller you have managed to destroy the enclosure of that one.
S Scott1706 New Member Jul 25, 2024 #23 Refuse to Bend said: Get an electrician involved to fit a new controller you have managed to destroy the enclosure of that one. Click to expand... Had to trim the plastic on the side so wire would fit flush
malbec4 Screwfix Select Jul 25, 2024 #24 Scott1706 said: Had to trim the plastic on the side so wire would fit flush Click to expand... Trim? Is that the correct word?
I Ind spark Guest Jul 25, 2024 #25 malbec4 said: Trim? Is that the correct word? Click to expand... Yes, trimmed with an axe
S Scott1706 New Member Jul 25, 2024 #26 Just to confirm I'm an idiot, I had set it up correctly just forgot to turn the isolator on Working fine now thanks for advice everyone
