Help With Flooring
Discussion in 'Carpenters' Talk' started by spannerw, May 18, 2020.
  1. G Roo
    G Roo Member
    Floating chipboard floor? Insulation under chipboard? Ground floor... think I'd be expecting solid concrete or block and beam..not joists
  2. Abrickie
    Abrickie Screwfix Select
    Not sure it matters in this case, as long as you take the dip out, don’t look at the bubble on your level you’re after flat not level ;) Starting at you internal door may be an idea you don’t want to end up with too noticeable lip there ;)
  3. spannerw
    spannerw Active Member
    Cheers Abrickie
    Am actually running it through the internal door and into the hall as the existing flooring does the same.
  4. spannerw
    Just wanted to say a massage thank you to all those who gave expert advice on my flooring. As you can see it is now finished.
    Thank you all you cheap handymen ;)
    fff and Jord86 like this.
  5. Abrickie
    Looking good, like the recessed mat :) I know a property developer who may put some work your way;)
    fff likes this.
  6. spannerw
    Yeah I’m happy with it more importantly so is the wife!
    6 mm ply, wooden fibre underlay and 10 mm laminate. Like you say it’s not level but it’s flat!!
    Yeah the mat was a pain in the backside to do but glad I did it.
    Mr Rusty likes this.
