Help !!
Discussion in 'Just Talk' started by Ronstin86, Oct 12, 2017.
  1. Ronstin86
    Ronstin86 New Member
    My cat has came out of the gas cuburd with a blanking disc. ...what are these for ?? Do I need to call a gas man / woman out in case of a gas leak ??
  2. Dr Bodgit
    Dr Bodgit Well-Known Member
    As in a blanking disc that is used to "blank off" the gas outlet when there is no pipe fitted? Its likely this has been left behind in case its needed at some future date. I have one loose by my gas meter, its was used by SGN when the gas meter was moved, then the disc was removed when the plumber connected up the gas to the boiler. I just didn't throw it away.
  3. KIAB
    KIAB Well-Known Member
    One of these.
    Cat would need an adjustable spanner to remove it from a capped off pipe, probably a discarded or spare one, if gas was leaking you would smell it.:)
    [​IMG]
    Ronstin86 likes this.
  4. Dr Bodgit
    Mine was a flat black plastic disc, I think.
  5. Ronstin86
    Yes jus like tht one bit with a black rubber thing around it lol I no about this stuff lol
  6. KIAB
    Black rubber is just the sealing washer.
    [​IMG]
  7. Isitreally
    Isitreally Well-Known Member
    Lets hope your cat is Gas Safe Registered. :p:p:p
    CGN likes this.
  8. Dr Bodgit
    More like CAT safe registered.
