Helping stripping oak beam
Discussion in 'Painters' Talk' started by animalmother90, Aug 25, 2019.
  1. animalmother90
    animalmother90 New Member
    hi all
    Bought some Paint Panther to strip the paint from an old oak beam. The top couple of layers came off great but there’s a white layer just above the bare wood that doesn’t react to paint stripper and I’m worried about sanding it off in case it’s lead paint. Any ideas?
  2. Astramax
    Astramax Super Member
    Could be distemper if should wash off with wire water with the help of scotch brite scouring pad.
  3. KIAB
    KIAB Super Member
    Got any more beams,timber need stripping, if so look at Soda Blasting will strip off paint & grime without damaging timber.
    Quite a few firms around the UK who offer a mobile service.
    http://www.blownawayuk.com/
  4. sospan
    sospan Screwfix Select
    To me it looks good like that
    But as previously mentioned it is probably a lime based paint which should scrub off. The only concern is to avoid any lime products going into your eyes because it will burn quite severely
