Hi, i pools of water below floorboards
Discussion in 'Getting Started FAQ' started by Mickle1uk, Jul 22, 2020.
  1. Mickle1uk
    Mickle1uk Member
    I recently raised some floor boards and found deep pools of water underneath around foundations any ideas why.
  2. Peterdevon
    Peterdevon Active Member
    Could be leaking pipes, leaking drains, ground water or even the sea depending where you are.
  3. Wayners
    Wayners Screwfix Select
    Seen it before. Water from downpipe overflowed or found its way through crack in drain collection gully. Eroding soil under house and flowing under. Inspect all drain collection and clean out drians. Put bin liner over your arm and scoop out the muck. Any cracks or open joints around the drains? All they water going down the drain?
