CAN SOMEONE HELP WITH THIS IS IT CORRECT THAT A BALANCED FLUE BOILER CAN"T BE INSTALLED ANYMORE IF THIS IS THE CASE PLEASE EXPLAIN WHY
no it is not correct. balanced flue boilers can be installed as long as they're condensing boilers. all boilers have to be condensing now
a balanced flue boiler cannot be fitted as a balance flue boiler is only 75% effeiant, you have not been able to buy a balanced flue boiler for about 15 years now,
thats funny as i work on balanced fan flued boilers every day and warmfront are installing them every day!
a balanced flue is a square flue usually about 6 inches by 9 inches retangle, although sizes vary with the output of the boiler, they completely rely on the burner to 'suck' the air in and exhaust the burnt fumes, they have no fan, all boiler now and the last 12/15 years have fanned assisted flues, they are not called balanced flues, but fanned flued
Jeez, Elvis - what are you on?. A fan flued blr IS NOT balanced, although both are room sealed. As said, there are no condensing balanced flue boilers, theref ore you can't fit them.
ahh don't you wish dick honeybucket puller was here to see this thread, he would have had such fun replying to elvis, ahh well, must move on,
graceland.. how the * are you gas safe reg ?? did u give the examiner a back hander ?? shocking how clueless some registered engineers are. [Edited by: admin]
balanced flue, room sealed, fan flued all the same. Exaust and air intake air at same atmospheric pressure I.E. balanced
there we go,fixed it for you .... fan flue(ff) or powerflue(pf)is fan flue balance flue (bf) is balance flue both are room sealed appliances
HELLO CHAPS...THANK YOU FOR YOUR ADVICE CAN I JUST SAY I WAS READING FORUM..I AM A TIME SERVED HEATING ENGINEER GAS SAFE REGISTERED AND HAVE RUN A SUCCESFULL BUSINESS WITHOUT ANY BREAK FOR 27 YEARS I MADE UP QUESTION AS I NOW THE ANSWER IS ONLY CONDENSING BOILER IS NOW PERMITED TO BE INSTALLED AND THERE IS NO DOMESTIC BALANCED FLUE BOILER ON MARKET AND THERE FOR OLD NONE BALANCED FLUE ARE NOT FOR SALE IN ENGLAND WALES AND IRELAND BUT CAN BE PURCHASED IN SCOTLAND..BUT ARE DEEMED TO BE A IRREGULAR INSTALLATION AND THERE FOR NOT TO BE SOLD....ONLY ONE MAN NEW THE ANSWER AND ANSWERED CORRECT...THE IDIOT CALLED ELVIS IS A COMPLETE CHANCER AND A COWBOY WHO HASNT GOT A CLUE WHAT HE IS TALKING ABOUT AND HASNT GOT ANY UNDERSTANDING OF FLUE TYPES AND CORRECT TERMS AND CLEARLY HAS NEVER DONE A CCN1 AND IS NOT GAS SAFE REGISTERED...JUST THINKS HE IS CLEVER....BUT A IDIOT THANK YOU TO THE TRUE PROFFESIONAL WHO ANSWERED CORRECTLY
Extract from Viper manual- 'Room sealed appliances provide the solution to a number of problems associated with open flue systems. Appliances of this type are purchased as a complete unit which incorporates the flue system. They remove the need for a potentially costly and elaborate flue system. They also provide an extra level of customer safety being room sealed. There are two main types of ROOM SEALED appliance:- Balanced Flue (The most common type) Appliances specifically designed to be used in a shared flue system
balanced flue, room sealed, fan flued all the same. Exaust and air intake air at same atmospheric pressure I.E. balanced Isn't this what I said?
