Hiding a bent blind railing
Discussion in 'Kitchen Fitters' Talk' started by Iron_Mike, Sep 10, 2018.
  1. Iron_Mike
    Iron_Mike Active Member
    Hi
    My blind rail has to be set at a bent angle in order to make it come down straight.
    Initially I had the rail set square using a laser level and working off the "straight" grout line on the tiled splashback below.
    However due to the floor tiles being off, the tiled splashback is also slightly off.
    I had to angle the blind rail by 4cm to make it come down straight.
    As the rail looks fairly ridiculous being so bent, I am looking at the best way of hiding it.
    Is my best bet to install a wooden batten in front of the rail in order to hide this error?
    Video attached as this should clearly show the issue I am based with.
    Cheers
    IM
  2. Astramax
    Astramax Well-Known Member
    Have you considered 'Ye Olde pelmet'
    KIAB and Iron_Mike like this.
  3. KIAB
    KIAB Well-Known Member
    :eek:
    Are they still used in the 21st century...[​IMG]
    Iron_Mike likes this.
  4. Astramax
    Sounds so much better than a 'bodge cover strip' don't you think!:D
    Iron_Mike and KIAB like this.
  5. Iron_Mike
    Thanks Astra, didn't know they existed.
    Not many people look like they sell them individually :(
  6. Astramax
    Sounds like a hand crafted one is going to be the order of the day!
  7. Iron_Mike
    Yes a timber pelmet shouldn't be difficult to construct.
  8. KIAB
    Years ago you could buy them,then they seem to go out of fashion,now they are popular again,funny thing is they can finish off a room at times, actually like them myself,& I see quite a few firms have them available now in mdf/ply,painted,stained,or fabric covered, crazy prices though on some,but it's a easy job to knock one up.
    https://ajmcustomdesigns.weebly.com/painted-mdf-pelmets.html
  9. Iron_Mike
    Cheers KIAB
  10. Astramax
    Mine were put up when the property was originally built in 1938, been up so long now they have come back in fashion!:p
    KIAB likes this.
  11. chippie244
    chippie244 Well-Known Member
    It wouldn't even need a pelmet, a panel a bit wider than the reveal and hiding the blind would be fine.
  12. Iron_Mike
    Cheers Chippie
