Hive heating help please!
Discussion in 'Plumbers' Talk' started by GregHugs, Sep 24, 2021.
Tags:
  1. GregHugs
    GregHugs New Member
    Hey all. I'm sorry my first post is asking for help.
    I recently bought the hive heating system. My set up is old.. my oil boiler is wired to a switch with just three wires. I only need hive to switch off and on and can only install it between the boiler and the plug. I have power going to the hive and it is ok. But I don't know how to form a circuit with the brown, blue and green wires to the boiler from hive. I've searched for hours with no success. I just need off and on! Any guidance would be life saving as my other half is cold.
  2. sparky steve
    sparky steve Screwfix Select
    What make and model of boiler do you have.
    Do you have a programmer?
  3. GregHugs
    GregHugs New Member
    It's a 25 year-old "Euroflame" with a built in programmer. The actual burner is a year or two old. I currently control it using a smart plug (just off and on). I want it running to the fused switch with the hive between it and the boiler to control just the on and off.
    And thank you for replying
  4. adgjl
    adgjl Active Member
    Does your boiler do the hot water as well as the heating?
    Do you have a hot water storage cylinder?
    Have you bought a single or dual channel Hive?
  5. GregHugs
    GregHugs New Member
    The boiler also heats the water.. so when the boiler is off, water is heated by emersion. Not ideal but it's like that until I can upgrade.
    It's a single channel hive
  6. Mike83
    Mike83 Screwfix Select
    If you want to go down the hive route that’s fine. It probably won’t work as well as it could but the wiring should be simple enough.
    Give the hive a LNE from the plug/switch.
    Link hive Live-terminal 1.
    Then take a NE from the hive to the boiler.
    The boilers live supply will come from hive terminal 3.
  7. GregHugs
    GregHugs New Member
    Thanks Mike. I am really just using it as an expensive on off switch the the time being. Can you just explain where I might put the live and neutral from the boiler to the hive? I don't need to bridge anything?
  8. jonathanc
    jonathanc Screwfix Select
    Before you connect it that way you need to confirm the max load of the boiler is less than the max switching load of the hive.if you cannot confirm that you risk overloading the hive
  9. GregHugs
    GregHugs New Member
    Yes. I had that checked. I'm just still at a loss as to what wires go where and I live rural, so it could be a week before I can get professional help.
  10. GregHugs
    GregHugs New Member
    So it's no problem getting power to the Hive . The problem is where do the wires to the boiler, which previously went to a three pin plug, go.
    I really really appreciate the help
  11. jonathanc
    At a guess without reading any more of the instructions
    Bridge L to 1
    connect boiler neutral and earth to neutral and earth and boiler live feed to 3
  12. GregHugs
    GregHugs New Member
    Thank you. Tried that. Still no joy. So frustrating. I just need to complete a circuit between "brown and blue" using 123 and 4 in some combination!
  13. jonathanc
    ok so is 1 connected to 2 when no heating is demanded and 1 connected to 3 when heating is required? Bit of testing needed
  14. GregHugs
    GregHugs New Member
    I just have the live and neutral running to the boiler from 1 to 3 to achieve that and with the set up I have, I can't be certain there's even power going to 1 to 3 with the mains connected to L and N ?
    I normally get professional help on these things, but I was desperate.. I can re wire the 3 pin plug in the meantime I suppose. It's like trying to read a language you don't speak and it's embarrassing!
  15. jonathanc
    Post up a picture of how you wired the hive according to my post at 11:54 please
  16. Mike83
    Think of it like this.
    You have one cable from the plug to the boiler.
    Cut the cable in half.
    Put the 2 blues in hive neutral.
    Put the brown from the plug into hive live.
    Put the brown to the boiler in hive 3.
    Fit a bit wire between hive live and hive 1
  17. GregHugs
    GregHugs New Member
    Excuse the mess.. I've just roughly rearranged for the picture
  18. GregHugs
    GregHugs New Member
    What do I do with the blue to the boiler?
  19. GregHugs
    GregHugs New Member
    This did it. Thank you so so very very much.
