Simon Whitaker
New Member
Hi there,
Was hoping to install a new Hive thermostat myself - but turns out it's not as simple as switching over from the old temperature wheel one...
It's a Hive Mini single channel receiver, and we have a Main Eco Elite combi.
The old one is a simple two wire setup - supplied by twin and earth cable(earth is just loose on both ends). On the boiler side it only has switched live in and 230v live out which is currently hooked up to the old thermostat (as well as the fused neutral, live and earth supply).
I've attached images below.
Can someone advise on the wiring setup for this please? The thermostat requires a permanent live, so could I take that from the live supply on the boiler, then boiler switched live to the 3. Heating ON terminal on the thermostat, and neutral as is?
I can run new 3 core and earth cable - although I have seen someone suggest you would I get away with utilising the earth, marked with a brown sleeve - but I'm guessing I shouldn't do that...
Any advice would be greatly appreciated!
