Hive receiver move
Discussion in 'Electricians' Talk' started by Retired62, Oct 9, 2019.
  1. Retired62
    Retired62 New Member
    Just had boiler moved into loft to allow extension to be built, heating engineer put Hive receiver next to boiler. As the receiver has the manual push button to turn heating on if anything goes wrong with system, I was thinking of moving it to a downstairs cupboard next to a fused outlet, as it has 5 core round cable (4 plus earth), what size cable should I use, would 1mm2 be ok.
  2. Mike83
    Mike83 Screwfix Select
    It probably depends on the length of the cable.
    I would think it would be fine.
  3. Retired62
    Cable length will be about 8 metres.
  4. seneca
    seneca Screwfix Select
    It's most likely on a 3a or 5a fuse in which case the 1mm will be fine.
  5. peter palmer
    peter palmer Super Member
    Even 0.75 flex is more than adequate but it depends on how its been wired, is these already a spur next to the boiler for power? you suggest powering it from a spur in a cupboard instead, it would be a bad idea to power the hive from one spur and the boiler from a different one, would give someone a nasty surprise if they thought they isolated everything at the boiler but another supply was live elswhere.
    Best way would be to leave the spur in the loft and run a 5 core down the hive and power it just from the 5 core flex.
