Hive & Underfloor heating
Discussion in 'Electricians' Talk' started by JezzaH, Jan 12, 2018 at 8:38 PM.
  1. JezzaH
    JezzaH New Member
    Hi, I have recently built a ground floor rear extension to my house and installed underfloor heating. The rest of the house is heated via combi boiler central heating with a Hive controller.
    I am looking for info on how to wire up the 2-way valves and an additional Hive controller. Any help appreciated
    Many thanks
  2. leesparkykent
    leesparkykent Well-Known Member
    Do you also have a pump on the manifold? Has a two port valve been install on the existing rad circuit as well? Has it been piped so they will work independently?
  3. JezzaH
    JezzaH New Member
    Yes, yes and yes...
  4. leesparkykent
    What boiler do you have?
  5. JezzaH
    JezzaH New Member
    Viessman vitodens 100
  6. leesparkykent
    what existing thermostat do you have for the other heating?
  7. JezzaH
    JezzaH New Member
  8. leesparkykent
    Grey is perm live, blue neutral, green&yellow earth, brown switch live from controls and orange switch live to boiler. Link live to common and connect brown of the valve to terminal 3. The bodge way to wire the pump is by connection it to terminal 3 with brown of the valve. The proper way is to use a relay and use orange to switch the coil instead of the boiler directly. So the Valve is open before the pump kicks in.
  9. JezzaH
    JezzaH New Member
    Many thanks. I'l give you some feedback once it' done. Again many thanks Jez
