Honeywell HC60NG/HCW80 To T4 wiring?
Discussion in 'Electricians' Talk' started by Averrcus, Jan 30, 2020.
  1. Averrcus
    Averrcus New Member
    Hi everyone, I just need some help wiring from the old HC60NG relay and thermostat for the new T4 thermostat. I’m completely new to this but was told at the shop that the two are compatible. From what I’ve researched, the blue wire is the neutral and won’t be needed in the new one? But I’m completely lost for all the others.
    https://imgur.com/NapdfeT
    https://imgur.com/WAPVeM7
    First picture is the old one, second is the new one.
    Thanks.
  2. PandA3
    PandA3 Member
    Hi
    The T4 is battery powered so no neutral required.
    Your red goes to A and yellow To B.
    The blue is not required so terminate safely in back of box.
    The little red link wire is not required.
  3. Averrcus
    Averrcus New Member
    Thank you!
